I want to make a VCD but the file is to big how do I cut it so I can put on 2 discs
You can use the free version of TMPGEnc which has a limited mpeg editing feature.
https://www.videohelp.com/tmpgencedit.htm
Hope that this helps.Cole -
Be warned - TMPGenc's editing function is notorious for causing horrible audio sync problems on some PCs that use it. If it happens, it will happen on the 2nd disc.
You may get lucky and it may work fine for you. The best editor I ever used is still MPEG2VCR at http://www.womble.com. It's not free, but it's a great program. You could use MPEG2VCR to split your video file.
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 16:44 -
Splitting Mpeg-2 DVD files..
By Veepa in forum EditingReplies: 2Last Post: 11th Mar 2010, 04:25 -
Splitting vob(mpeg)
By Peterrrrr in forum EditingReplies: 4Last Post: 17th Nov 2008, 12:24 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 08:18 -
splitting an mpeg-2?
By php111 in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 18:18
