jUST GOT AO3 BURNER, TRIED TO RIP MOVIE . RIPPED ok. WENT TO NERO AND THOUGHT I SET IT UP AS BEST AS I COULD, BUT AFTER BURNING WHEN I TRIED TO REPLAY MESSAGE (UNKNOWN FILE? ) CAN ANYONE HELP OR IS THERE A GUIDE WHER I CAN PROPERLY LEARN STEP BY STEP TO DO THIS ? i RIPPED AS A (BACKUP) ALL FILES. VOBS,IFO, BUP > Thought i was copying all files as a clone.
New to this, would appreciate any & all HELP.
Thank You in advance.
Results 1 to 9 of 9
Dreamer
It is that easy..as long as you burn in the UDF/ISSO 9660 bridge mode..keep in mind, that this only works on DVD less than 4.3 GB, anything else you will have to cut extras out or reencode the movie..
O and NO NEED FOR ALL CAPS!!!!..its considered screaming.
<font size=-1>[ This Message was edited by: Kdiddy on 2001-12-28 23:10:23 ]</font> -
Thanks kdiddy, the movie was less than 4.3 gig. You noted (Encode?) Must i encode it ? I took the vobs,ifos,and others after ripping and went directly to nero where i used the udf/iso bridge . If i must encode what are the settings and format that i am supposed to use?? Would appreciate any help. PS Thanks for letting me know about the caps. didnt know that.
Dreamer -
you will only need to reencode if the movie & extras is over 4.3 GB....if not, just rip & burn....reencoding is a WHOLE different issue that isnt even worth the trouble, easier to just buy the DVD
kdiddy, itried that but the dvd disc i burned wont play, when i try it comes up something like (file unknown) ?? Should have written message down. Any ideas. Thanks. PS; what if i just burn the vobs only and the ifo, can i still use the dvd functions on a stand alone ? and what is a bup ??
Dreamer -
The files you ripped must be in a folder called VIDEO_TS and there must also be a AUDIO_TS folder which is empty. This has worked with all the DVDs Ive burned so far
Are there any how to's for the PioneerDVR-A03. I see a lot of stuff about ripping to CDR/W (VCD/XVCD/SVCD). How about simple copying to DVD-R(W) disks - or isn't this that simple either. I've successfully burned VCD's and XVCD's. I'm looking to jump to DVD-RW. Do we have how to's? Does the software that comes with the DVR-A03 do this for you? Does it come with software.
Dale -
Look for CHUMBOY in the threads. He was of so much help to me in regards to do dvd to dvdr along with articles/threads from Derrow. These 2 people are simply AMAZING !! and kind enough to help me along. I cant say enough good about them. Not to forget Sefy as well in regaards to vcd/svcd. My many thanks to others as well. May all have a Happy & Safe New Years.
Dreamer -
newenglander, thank you for the compliments, and i'm glad to hear I was of help! may you all have a wonderful and happy new year!
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
How do you copy a DVD onto your IPOD? I have DVD Fab Ripper, any good?
By jacknscoob in forum DVD RippingReplies: 1Last Post: 18th Jan 2012, 04:28 -
Invalid DVD folder in Wondershare DVD Ripper after using DvdReMake
By doofuz in forum DVD RippingReplies: 30Last Post: 2nd Dec 2010, 09:39 -
DVD Ripper Doesn't Rip Full DVD
By hughgogirl in forum DVD RippingReplies: 11Last Post: 31st Dec 2009, 13:27 -
DVD Decrypter problems - I want the very best DVD ripper
By Lovepeaceguru in forum DVD RippingReplies: 3Last Post: 11th Nov 2007, 19:54 -
ImTOO DVD Ripper, can't rip my DVD's!!!
By Hashum in forum DVD RippingReplies: 20Last Post: 11th Oct 2007, 08:35
