if i import my raw DV Encoder1 .AVI files into Mediastudio, trim and
cut the video
(to eliminate un needed video) and then re-save as the same .AVI
format, will I lose any quality?
I would like to do this because i have huge raw capture files, but
only a fraction of it is actually good footage, and i wan't to save
diskspace. I can't lose any quality however, or it's not worth it.
There is no re-encoding providing your output spec is the same as the source. If you are just doing straight cuts it should only take a few seconds to create the new file. If you have put any transitions or filters in, make sure smartrender is checked when you create the new file. Only the sections containing transitions will be re-encoded.
No, you should not be losting any quality. I do this all the time. Just make sure you're saving in the same format.
AVCHD editor Sofware with lossless video output,which can handle PSF format
By Stears555 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 14th Feb 2012, 04:56 -
Saving Vegas 9 Video-Clip in Older Format
By TKB in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2011, 05:07 -
WMV File with YUY2 Raw Video Format
By toreachdeepak in forum Video ConversionReplies: 3Last Post: 24th Feb 2011, 10:43 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Best format for saving home video
By lehoczky in forum Newbie / General discussionsReplies: 24Last Post: 28th Jan 2009, 09:39
