Results 1 to 10 of 10
    Dec 2005
    Are there any good DVD burning [not copying[ softwares that's as good as or even better than Nero? If so, what are they please? Thanks.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
  3. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Prassi Ones, is all I use for either CD or DVD burning.
  4. Stomp RecordNow works great for me.
  5. I am a long time user of Easy CD Creator (even when it wasn't so easy).
    I currently use Roxio's EMC7.1 for all optical media burning - and it works great on my system
  6. Aging Slowly Bodyslide's Avatar
    Feb 2002
    Prassi Ones new upgrade to 2.0.325 has a bug in it that will not allow you to burn a VIDEO_TS folder. I emailed tech support who responded very quickly that they have recevied over 1000 emails on the issue. Another update will be out this week that corrects the issue.
  7. ImgTool Classic + ImgBurn or DVDDecrypter
    Sonic RecordNow Deluxe (uses Prassi burn engine)
    Both ideal for DL burning.
  8. LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
  9. Prassi ONES
    & thanks for the HU on the bug in the new version, bodyslide.
  10. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A few folks also commented on it besides me. So thanks to all who reported the errors.
    New Version is out will Test it and report Back.
    http://www.traxdata.fr/www/pdf/ONES_Update326.zip
