Hi,
I'm having trouble playing back authored DVDs on my set-top DVD recorder. The problem is that the menu just displays a black screen, although the video content itself is playable, whereas the same disc on another DVD player works fine.
I'm certain that this is not a media / read error problem: if I press "stop" from the black menu screen (to display the manufacturer logo screen) then play, it starts playing the first title on the disc, and I can then navigate around titles and chapters using the "T/C" button. All of the video plays fine - no pauses, skips etc. I have burned the same set of files to a +RW and a +R disc, both of which give the same results. I've even scanned the discs for errors using "K-probe", which gives acceptable results. Finally, the discs work fine, including the menu, on an older DVD player which I know to be very picky about media quality.
The files were authored using "GUI for DVDauthor", and burned using NTI CD-and-DVD Maker, in video mode. While experimenting with different authoring software I also authored a disc with Tsunami DVD Author, which gave similar results. I did get one disc from GUI for DVDauthor to work though, so I know it's possible - but that one had problems with the video editing so I erased it.
Any ideas what's causing this? I'm guessing it's either something in the menu files that the machine doesn't like, or a file structure / disc layout problem. Any suggestions what to try next?
Thanks!
If you search/google on your specific prob., including player model, *might* find someone else who's had the same prob.?
Only guess I can think of is if you're using video for menu, try another method of creating/encoding, &/or make sure it's corect size/aspect etc... -
Did the search as suggested, and there are mixed reports on CDFreaks of this DVDR model playing PC-authored discs, so it seems the machine is picky. But none with exactly the same problem as mine, and some people report that it definitely can play them.
No video in the menu, just a still image.
I noticed that when it brings up the blank menu screen, the TV switches to 16:9 mode if I had set the menu aspect ratio to 16:9 in the authoring app. So it is managing to read as least some of the menu data! -
Sorry for answering so late, I just missed you post
Some tips for picky players:
- Try to set the 'number of frames for still menus' to 12 (permanent settings)
- Do not use audio as background music for still menus (no problem with animated menus if audio and video have the same duration)GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Changed this setting and ran the authoring again... and sure enough, it works!!- Try to set the 'number of frames for still menus' to 12 (permanent settings)
Many thanks for the tip.
For the benefit of anyone searching, the DVD recorder model is Philips DVDR-3305.
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30 -
Comnimng Authored DVDs To One Disc
By phantomengineer in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2011, 22:23 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
Home-authored DVDs and Older Players
By ctdvd in forum Newbie / General discussionsReplies: 8Last Post: 3rd Aug 2007, 01:32 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
