A couple of points, if anyone can help (have tried the Search and How Tos):
- Has anyone used this combination successfully? And, if so, with what results?
- Is there any way of using PAL 720 x 576 caps done with a Pinnacle DC10plus and the Pinn. DV 500 card in Premiere 6? On importing, I get the error
'Unable to open that file. File uses an unsupported compression format.'
(Previously, I've edited my analogue Viewcam footage in Pinnacle's Studio 7 and am only now experiementing with Prem.)
Results 1 to 9 of 9
Haven't tried/used that combo, but what format is the captured vid? Sounds like Prem just can't find a codec, but give format info & should get many replies.
Sorry, I thought I had given the format info - PAL Viewcam video 8 captured by a DC10plus and the DV 500 cards, at the above res, as an AVI. Have I missed anything out?
Usually, I just open the cap in Studio and archive away. Since I'm trying Prem, both v6 and Elements, it was frustrating to find that it wouldn't import them. (Am now looking at v6.5 to see if that would import it correctly.) -
Let me try to respond. The DC10plus (MJPeg) and PVR-500 (MPeg1/2) cards are both hardware encoding cards. Premiere Elements is targeted for DV format and may allow uncompressed YUV. I don't have it.Originally Posted by japniz
Older full Premiere versions supported editing in Pinnacle's MJPeg format using specific drivers co-developed by Pinnacle and Adobe. Support for these older cards stopped at version 5 although some people have gotten them to work for v6.x.
Neither full Premiere nor Premiere Elements (any version*) support direct editing in MPeg. If MPeg is imported, it must be decompressed and "conformed" to one of the supported Premiere project formats.
* Mainconcept sells a native MPeg project capability as a Premiere Pro plug-in for $250. This will allow native MPeg editing with Premier Pro.
http://www.mainconcept.com/mpeg_pro.shtml#standardRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
EdDV, many thanks for your detailed answer.
(The second card I was using, by the way, was a DV500 rather than the 'PVR-500' you mentioned, unless they are one and the same under a different name.)
The plug-in you mention is way beyond my budget and only for Pro, which, again, is just a pie in the sky ap for me.
Looks like I won't be able to capture into Elements with the DV500 from what you say. I've only got a few tapes left, in any case, so will complete them in Studio and wait till I'm ready to edit the recent DV material I have from a more modern cam for Prem and/or Elements. -
oops
The Pinnacle DV500 card is supposed to support DV format. Best ask in a Pinnacle forum.Recommends: Kiva.org - Loans that change lives.
Yes, Prem. was actually bundled with the DV500 card.Originally Posted by edDV
And therein lies the rub. Recently acquired by Avid, most of the Pinnacle forums for legacy products I find are now closed to new posts. Hence, me coming here after looking there first.
Again, thanks. -
Maybe the DV500 needs special drivers to work with Premiere. You may be stuck with the original Premiere version just like I was with the DC30plus card which got stuck on v5.1.
Thanks, EdDV.
Looks like I am unless anyone posts with a different experience using the card and Prem/Premiere Elements 2.
Prem Pro CS 5.5 + Lagarith anyone? et. al.
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 14th Oct 2011, 15:13 -
Vista Ho-Prem and versions of MSWMM
By wguru in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2009, 19:47 -
Pinnacle DV500 Plus crashes on installation
By Dr.Rock in forum Capturing and VCRReplies: 2Last Post: 12th Feb 2009, 13:27 -
Adobe Prem 2.0
By caeK in forum EditingReplies: 1Last Post: 1st Jul 2007, 12:21 -
Pinnacle Studio Plus Titanium 10.5 versus Adobe Premiere Elements
By bowmah in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2007, 17:48
