Well, yesterday my HD died. It's a Seagate SATA 250gb. I turned the computer on and the HD is not accessible on Windows Explorer (it says I need to format) and on Disk Management it says the disk is unaccessible. From the help file it seams like the problem is hardware, like the headers or something.
How could I save my data back? Buying a new HD from the same model and exchanging plates would be my only option?
Did any of you have this problem?
I can't believe I lost more than 220gb that were usefull for me.
Bruno
Thread: Will I ever have my data back?
Bruno,
Firstly, I run two of those hard drives in my PC and they contain lots of important information...
Possible solution:
http://www.seagate.com/support/index.html
Try SeaTools - it's diagnostic software, and might be able to tell you what's up with the drive and perhaps even rescue it.
I don't know enough about this sort of thing to really help you, I'm afraid. If you could post up the result of a full diagnostic using SeaTools, it might help though.
Good luck!
Cobra -
Man, can you believe I forgot the check Seagate's site to look for help? I'll do it as soon as I get home (in about 3 hours). I'll try both "online" and "desktop" SeaTools options.
Thanx for the tip -
use FileScavenger!!
i had the same situation -- Windows said the drive needed to be formatted even though I had a great deal of data on there. Disk Manager said it was unaccessable.
FileScavenger saw it just fine and extracted almost all of my files from the drive.
definitely worth the small price of the program"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Originally Posted by Xylob the Destroyer
This assume that your hard drive motor is spinning and the BIOS can recognize the drive, anyway -- an absolute hardware failure of the drive is difficult to recover without physically tearing the drive apart and paying $$$$$ to get a data recovery service to extract it.But if the drive at least spins, if it at least shows up in the BIOS, even if Windows can't see it, file scavenger can.
Caveat: Take that drive out of the computer NOW and don't touch it until you're ready to restore. Put it in a safe place and LEAVE IT ALONE until you get the software, have installed the "dead" drive as a secondary drive, and then go. Because you may or may not have much life left in this drive and you don't want to find out the hard way that it was good for three more hours and that was it. -
Sorry, I couldn't reply on the weekend.
Thanx Xylob and ozymango! File Scavenger found everything on the hard drive! I remember reading about this software somewhere a long time ago, but I would not remember it.
Now I just need tosave some money and buy a new HD. I won't keep using the drive even if I recover everything.
Thanx a lot!
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 17:53 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 08:00 -
Burning Data at 4x
By rickoshay in forum ComputerReplies: 9Last Post: 19th Feb 2010, 14:05 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 20:03 -
data redundancy?
By beer31 in forum ComputerReplies: 5Last Post: 23rd Aug 2007, 00:32
