You mean that the info window says 'skipping frame'? Don't worry about that, it won't be noticeable on playback... I'm not sure what it means though, I guess small glitches in the source file, or maybe it is caused when converting to a different framerate then the source file.
Thanks for that, but the video actually skips frames - wheather I load the ts files in apple DVD player or burn to disc. I've checked and double check that the video and audio rates are the same as the source when I drop into ffmpeg, but for some reason it still skips frames, going from 12 sec to 18 sec to 22 sec etc., on the counter in DVD player.
Just can't get my head round it!
Somebody asks this question every week in this forum. It should be made into a sticky.
see https://forum.videohelp.com/topic322505.html
MPEG-4 frame skip problem - any way to fix it?
By TMHKR in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 07:42 -
No video and bad audio when converting AVI to DVD (ffmpegX)
By leosmith in forum ffmpegX general discussionReplies: 2Last Post: 29th Mar 2010, 14:06 -
ffmpegx problems with RM to AVI
By mgarman14 in forum ffmpegX general discussionReplies: 13Last Post: 2nd Sep 2008, 12:45 -
FFMPEGX problems- MOV to AVI
By ker-plop in forum MacReplies: 8Last Post: 30th Oct 2007, 11:43 -
DVD rip /avi thru MTR /FFmpegX - get wavy lines
By BattyRoy in forum MacReplies: 5Last Post: 31st Aug 2007, 09:06
