I have so far found 1 DVD recorder which matches the following spec:
plays Divx (and I think xvid)
records to DVDR/RW (doesnt matter - or + )
has a HDD also
USB port (allows access of jpegs etc)
The current recorder I have found is here.
This is kind of the price I am after. The only point with this unit is whether it allows to record to the HDD while playing a DVD. The manual from the manufacturers site doesnt make this clear![]()
I would appreciate anyones input
Regards
Timcs -
Since posting here I found other models, however I am unsure if they are of good build. Can anyone help, the following units are as follows :
Ellion 950S DVD HDD 160gb
Ellion 950c DVD HDD 120gb
H&B DRHD-120 120gb drive (same as the Ellion in looks)
Yamada DVR-9300HX 250GB HDD unit
I just need to know which of these would be the best to go for. The player I mentioned previously (eltax) has put me off due to reports about the fan being nosiy & apparently some other remote controls switching it on and therefore starting this fan up
Also are DVD recorders with HDD capably of recording a TV programme and watching a DVD film at the same time?.Regards
Timcs
Transform .m2v +. wav to full MPEG-2 dvd spec file?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2011, 09:13 -
HDV timeline footage to SD (16:9 or 4:3?) NTSC dvd spec MPEG-2 file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 19Last Post: 25th Mar 2011, 07:10 -
need some advice on some svhs and video cassette recorders
By gnrforever in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 16:57 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 23:23 -
DVD-Video Audio Spec. (Dolby 2.0) vs. Blu-Ray Disc Audio Spec. (Dolby 2.0)
By Disco Makberto in forum AudioReplies: 5Last Post: 31st May 2008, 15:30
