Results 1 to 11 of 11
    Jan 2006
    ok, so i really like that tmpgnc program...its easy to use and good quality...but since it only supports mpeg1&2 formats, im gonna need to convert my .avi's to mpeg1's...what is a good and fast program to use?
    What? TMPGEnc can open any number of source files. It only converts to MPEG-1 or MPEG-2. It reads pretty much anything you have codecs for.
    Jan 2006
    Maybe because im using the trial version...it says that avi's are an illegal format...
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    No, it's not that TMPGEnc doesn't support AVI (because it does) - it's that it has problems with that particular AVI.
    Read on here:
    https://www.videohelp.com/tmpgenc.htm#problems
    /Mats
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'm pretty sure you can output to AVI as well. TMPGEnc Plus can, anyway.
    If in doubt, Google it.
  6. Originally Posted by theendoffear
    If you mean TMPG DVD Author, then, yes. You can convert to mpeg1,2 with TMPGEnc.
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Me thinks Abond has had his crystal ball fine tuned!
    @theendoffear: Please use a more describing subject than "i need advice" - That's the reason for 99% of all threads here!
    /Mats
    Jan 2006
    Ok, so i download tmpgencplus and it has a place for video file and audio file...i can put the .avi in the video file, now what do i put for the audio file?
    Oh yeah, I forget about that. FILE -> OUTPUT
  10. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    ...now what do i put for the audio file?
    Assuming your video contains audio it should load it automatically for the audio source. You are following a guide I hope. There's lots of them for TMPGEnc and as you're a newbie to the program I recommend it.
  11. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If the AVI doesn't show as audio source when you set it as video source, TMPGEnc has found a audio type it can't handle. (Usually AC3) You then have to extract audio from AVI and convert it to wav first, then use the wav as audio source.
    And again:
    Use the Edit button.
    /Mats
