Is it possible to lower the audio on DVD's? I have a few home made dvd's with a loud volume that I wanted to lower without sacrificing the quality.
usually we get the opposite - how do I make the dialogue louder.
Demux the audio, use your audio editor to adjust the audio.
Remux the audio
How difficult this is depends on a few things
1. What format is the audio currently ?
2. Does the disk have menus, and if so, do you want to keep them ?Read my blog here.
It's 256kbps ac-3 with a basic thumbnail menu. Don't care for the menu, just want to lower the volume.
Use PX3 AC3 to WAV to convert your audio, then as Guns1inger said use any audio editor (eg Audacity) to lower the volume.
(Just remember when using PX3, to type the ".wav" extension after your output filename!)
I would use ffmpegGUI to reconvert back to ac3.
Lowering the size of video and editing
By imenica in forum Newbie / General discussionsReplies: 8Last Post: 21st Sep 2011, 14:23 -
Lowering contrast in H264 file
By carlmart in forum Video ConversionReplies: 13Last Post: 19th Jun 2010, 08:33 -
Avi lowering Frame rate and audio
By vipertongn in forum EditingReplies: 8Last Post: 14th May 2008, 03:31 -
lowering a framerate
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Feb 2008, 11:18 -
Does lowering the maximum bitrate, gain more space?
By Wile_E in forum Authoring (DVD)Replies: 2Last Post: 23rd Oct 2007, 20:37
