im using vuescan and need to scan some documents but need to edit them... which is the best format to scan to so i can convert over to a doc file
Results 1 to 9 of 9
Hi,Originally Posted by mol3000
First you need a OCR (optical scanning recognition) program that will allow you to your paper documents into your word processor where you can then edit them! .....
There several OCR progrms avail... not sure if any freeware.... you can check out download.com or tucows.com for that... I suggest go to your local office depot, or officemax or staples..... they generally have a variety avail plus you can talk to the clerks and determine which one is best for you..... something to note;;; some OCR work better with certain word processors than others.. so you may want to ask that...!! example of a ocr program is something like omni page.. but i am not saying that the best..... -
actually vuescan let me do that but for some reason its not saving it.... is it something im clicking wrong in the software???? i clicked on that option and it scans but it dont pop up like it use to.. and wont save it when i do it manully
OCR scanning is a tricky thing. OCR software will attempt to recognize characters on a scanned image and then attempt to format them how it seems them on this scanned image. It rarely works out like that. First of all the document usually needs to be clear black print on a white page done with an offset or laser printer. The font needs to be a typical roman font (though some programs will take all sorts of character but they cost a lot). Even with the ideal originals the OCR software will still place the wrong characters in places, sometimes resulting in incorrect spelling. If the letter or word is too mottled it will interpret it as an "image" rather than text data. Secondly the program's ability to lay out pages that aren't simply full text pages or columns of text is very spotty.
I use OmniPage at work for OCR scanning, but we're using it to scan legal documents to PDF so that the text within the PDF is searchable. The legal documents are pretty much text from top to bottom in a single column with hardly any odd formatting or spacing. Even then we still have to go through by page to make sure something wasn't dropped or spelled wrong. For the customer who wants, say, their old resume scanned in to make changes to it it's far easier for us just to start it from scratch than it would be to fight with the OCR software placing text all over. At least if we start the document from scratch we have full control of the formatting.
Barring all that and you still have a use for it expect to pay a few hundred dollars at least for a consumer-level OCR application. I wouldn't even mess with OCR at home, it's just not worth the hassle.FB-DIMM are the real cause of global warming -
ok, i really didnt want to add any more software to my computer if i didnt have to so can i just scan it to pdf and is there a pdf to doc converter?????
OmniPage will scan and save out to a Word file.
If this is just one page you could have retyped it by now in Word. Are these lots of pages you need OCR scanned?
Oh and if you do end up OCR scanning make sure to scan the pages at a minimum resolution of 400dpi. I've found this to be about the lowest most OCR software will take and yield the least errors. We usually do it at 600dpi though.FB-DIMM are the real cause of global warming
MD video file format - how can I convert it?
By bahjan in forum Video ConversionReplies: 6Last Post: 20th Apr 2010, 09:05 -
Convert FLV-file with H264 format into xvid?
By mccm in forum Video ConversionReplies: 2Last Post: 8th Oct 2009, 12:54 -
Best file format to convert MTS for editing?
By hanginthere21 in forum EditingReplies: 2Last Post: 18th May 2009, 19:38 -
Can I convert an .xba (video file) to another format
By TimBooth4Eva in forum Newbie / General discussionsReplies: 13Last Post: 23rd Jul 2007, 03:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
