Hi,
I can't understand why NTSC sometimes is listed as 23.98 fps and sometimes as 29.976 fps. Can someone please explain this to me?
Thanks.
For almost all capturing, and DV related context, 29.97fps is the standard signal for NTSC...
23.976fps is what Film is made with (Hollywood)...
Since NTSC and Film are two different formats, the Film framerate is "Pulled down" to create 29.97fps playback. Basically making five frames out of four...Check it out. -
Film runs at 24 frames per second. For converting the NTSC TV the film is slowed down to 23.976 fps. When broadcast on television it is telecined to 59.94 fields per second -- the only thing SD TV knows how to display. (Read up on 3:2 pulldown or telecine processes to understand this.)
On a DVD the MPEG file can be encoded as 23.976 progressive fields per second, or as 29.97 telecined frames per second. In the former case the DVD player performs 3:2 pulldown to create 59.94 fields per second. In th e latter case the DVD player performs 2:2 pulldown to produce 59.94 fields per second. -
AFAIK 23.98 (or 23.976) is a little bit uncorrect. Should be 24000/1001=23,976023976023976023976023976024 :P
Originally Posted by Abond
25 PAL to 23.976 NTSC AVI
By Nedward Orton in forum Video ConversionReplies: 8Last Post: 24th Mar 2012, 09:56 -
Convert 29,976 (NTSC) to 25,000 (Pal) AVI
By volker028 in forum Video ConversionReplies: 5Last Post: 23rd Mar 2012, 02:00 -
Divx to NTSC DVD: is Dgpulldown needed if Fps is 23.976?
By kalii2 in forum Video ConversionReplies: 4Last Post: 20th Jan 2008, 08:29 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34 -
29.976 to 25fps (removing pulldown from a NTSC converted PAL film transfer)
By ecc in forum Video ConversionReplies: 25Last Post: 15th Jul 2007, 22:31
