hey
Does anyone know how to change the bit setting (booktipe) with this drive?
BTW, the drive is also known as LG HLGWA-4162B
I've already try cd-dvd speed and dvd decrypter. None of them recognizes the drive as an LG, so they don't chang the bit-setting to dvd-rom
In the model I recently got (last year - HP DVD640c), the HP software included a utility called HP Disk Compatibility Setting.
That utility lets you change the bitsetting for DVD+RW (probably -, too) but not for the single use disks (DVD+R, -R).
If you are using DVD Decrypter, try burning one disk (+R for example) and then finalize it, eject the disk, reload it and let DVD Decrypter read the disk in File Mode [edit - oops, sorry, I should have said ISO mode].
The text analysis of that disk in the right text box of DVD Decrypter should tell you what the setting is for the written disk. Be sure to read through the entire set of statistics, data. I think you will find the disk has a final setting of DVD-ROM.
If true for you (as it is for me), then you don't have to worry about changing the bit setting anymore.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
I don't have that HP software.
But your drive is a OEM BenQ. Even with BenQ aplication, is possible to change bitsetting. The problem is that my drive is an OEM LG.
I've already try with DVD Decrypter. It burns with +R bitsetting.
According to some of the HP models that I have read through their specs within their website - some already burn DVD disks and finalize them as DVD-ROM bitsetting.
Maybe not all of the models, but considering what I saw from my 604c, I didn't have to modify the bitsetting at all. It finished that way with my first dual-layer burn.
Oh, I believe there is a better tool for doing this. I will look it up and forward the info once I get home from work.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
http://www.liteonit.com/ODD/Zip/BookTypeManual_e.pdf
The above link gives a good explanation.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=lpg41401
This link (above) describes and has a link to utility for setting Book Type for +RW.
http://www.k-probe.com/bitsetting-booktype-faq.php
This link has a lot more info.
The utlity that may work for you is Nero CD-DVD Speed version 2.20
It should be a free download.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.)
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 02:17 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
HDC setting question, 2 pass + manual bit rate
By jsbenson in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 20:15 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 12:12
