  1. Hi all,
    On The Gadget SHow on bravo earlier they had a device that could you could use to stream music from a PC to a Wi-Fi Hi-fi setup and you could use the remote control to browse through the music on your PC as it had an in built screen.
    Can anyone tell me what that device is called as I have forgot, and has anyone tried one and are they any good?
    Thanks guys.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Or if you have a xbox and a xbox wireless gaming device you can mod your xbox and do most of the same things.
  3. cheers Craig,
    Although the one I saw actually had a screen on the remote that you could select music/videos from a list and it would then play it through your hi-fi/home entertainment system (using one of the things you sent me to in the link).
    Thanks again.
  4. Member doppletwo's Avatar
    Dec 2004
    United States, Earff
    Originally Posted by Craig Tucker
    http://www.broadbandstuff.co.uk/product_info.php?products_id=273&osCsid=ca0a369e9f 6ead3374bf1b24d43a022e
    Never used one, but may consider one when the price comes down
    If only convopit dollars worked IRL.
    I love IRL.
    IRL is LOL IMHO.
    WTF?
    4 FTW
    snappy phrase
    I don't know what you're talking about.
