Hello,
Was just wondering what the best rated DVD/DivX Player is out there?
With best chipset?
Cheers ppl.
Oppo OPDV971H
http://www.oppodigital.comGoogle is your Friend -
Sorry i forgot to say im fom UK, wld it be easy to get hold of this?
im buying for someone else so i dont wanna spend too much cos im a tight bastard.. -
I'm not sure about all the differences between US and European standalone players. Besides the different format PAL/NTSC, I believe the power plugs are different.
Oppo has really good tech support, I'm sure they would be happy to answer any questions for you.Google is your Friend -
This is taken directly from the FAQ for this Oppo player at the web site listed above:
Q: What is the highest supported DivX resoluton for OPDV971H?
A: Currently, 720 by 480 is the highest DivX resolution that the OPDV971H supports.
I expected more than 720x480 support given all the raves for this player. The I-O Data Divx player claims to support higher DivX resolutions than that.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
