Im using Tmpeng 1.5 and use a mpeg 2 video and make a DVD. The video plays fine on the computer but after I burn the video to disk the voice will start to separate from the video. This does'nt happen with all burns and the beginning will start fine but after about 20 minutes the voice with then start to seperate.
Thanks in advance for any assistance
AMD 2300
XP Pro. 1gig ram
Radeon 7800 video card
"This does'nt happen with all burns and the beginning will start fine but after about 20 minutes the voice with then start to seperate. "
Media? -
Im taking it that your confused with my question ?
Voice dont match video on occasions when I make disk (Media)...
Will start skipping after 20 mins into the video. -
"The video plays fine on the computer but after I burn the video to disk the voice will start to separate from the video. This does'nt happen with all burns"
"Im taking it that your confused with my question ?
Will start skipping after 20 mins into the video."
Sorry... Just trying to suggest one possible troubleshooting route out of many. If the video plays good on your HD, & the DVD layout plays good on your HD, then the prob has to be between the authored layout and your TV.
Could be burning method/software - media - player I imagine. To me, buying some different media (that you're going to use anyway) is the easiest, but that's just me.
And of course, if the video doesn't always play fine from HD, or DVD layout on HD, then there are more possibilities.
How to Change your Voice to another normal Voice
By UmmAddan in forum AudioReplies: 2Last Post: 21st Jul 2011, 18:00 -
DVD-r Footage menu wont navigate ! Re- Author ?
By rockonvidtrade in forum Authoring (DVD)Replies: 2Last Post: 3rd Oct 2009, 18:42 -
Audio does not match with the video
By c018279 in forum Blu-ray RippingReplies: 1Last Post: 31st Mar 2009, 05:10 -
Video and Audio does not match
By hzgg2 in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 20:50 -
cant get audio to match video
By loa909 in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 07:35
