Hello
Im a reg user of QTPro, 6 edition. Ive discovered yhat some of mt QT file are 'normal' ie cot/paste work fine, while some files don't let me cut paste etv. the little cursors move, rtc but the cut/paste in the mrnu are not high lighted. in get info on these strange files it says i can read/ wright. what gives about this?
cheers rotuts
Results 1 to 12 of 12
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
On the files that it cannot cut and paste,
what are the file types? What does it say about them
in the Movie Info box?
The only files I could not cut and paste
protions of were MPEG-1 file types, because
they are muxed, and have to be demuxed
first before they could be manipulated.
Please post back."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Terr
you are exactly riught again. just before I checked my email for a reply I decided to look alittle more into the file reemmbering the movie info: the files that can't be cut/pasted were MPEG-1 MUXED. I had discoved I could export them with QTPro to a Divix or 3ivx format and then do the editing three and recombining.
so all ios well and my QTPro is working.
now to decided if I want to go to QT7 and pay for the pro there. has anybody used QT7 with the 'Flip4Mac' WMV file addition?
do you thihnk using that one can convert and edit WMV on the Mac? convert them to QT?
cheers rotutsMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
Well Terr
I was premature with my cleverness: the new files in 3ivx do indeed edit but they havo no sound!
lucky I checked before discarding.
do I hvae to then use aprogram like MPEG stremclip to convert to QT and keep the sound?
Ill play with that and report back.
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
Yes
passing those files through MPEG Streamclip did the job.
wonder why those files just don't work normally with QT?
should I post a thread other than this re: the Flip4Mac WMV 'patch'?
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
Dom
do you know if QT7 pro will work in both 10.3.9 and 10.4.4? I have a start up disk in each!
thanks for the info. if I can get qt7 to work in both OS's Ill pay jobs his 25$$
can you edit the WMV files in qt7pro?
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
Rotuts
I have the 10.3.9 version of OS X.
When you download the 'Flip4Mac' WMV file addition you get a trial version of 'Flip4Mac Import'. This allows you to import and export WMV files using QT Pro. If you want to continue to convert WMV files after the trial version expires, you will have to buy the upgrade ($29).
Domy -
I trashed the Flip4Mac freebie junk as it tended to hose my system and render my QT useless for many other tasks. Frankly, Window Media Player is more stable and Mac-friendly (so you know how poorly I judge the Flip4Mac stuff).
(QT 7.0.4, OSX 10.4.4) -
There is a known incompatiblity issue with Flip4Mac's
offerings and OSX 10.4.4...heck, it's been EVERYWHERE
since the iLIFE 06 announcement rumple...suprised you haven't seen it:
Macfixit, among others
For the record, Flip4Mac's stuff works great with OSX 10.3.9
and QT 6.52 (home), works fine with OSX 10.4.3 and
QT 7.03( work).
ANd rotus: MpegStreamclip properly demuxes first,
then recombines to make your 3iVX file.
QT will not if you just choose "save as" or "export"
and create the 3ivx file. You have to ( go the long way)
and first save the video, then go back and save the audio,
each as seperate files/filetypes,
then re-paste them yourself into a file and then save
that as the 3ivx.
I blame Apple solely for that foobar!"Everyone has to learn, so that they can one day teach."
Urban Mac User -
terryj,
Yeah, I know
about the incompatibility but, even if it worked on my (fully updated) system, there are a number of apps that expect to call WMP when req'd and the Flip4Mac stuff can't change the code in these other apps. (Not their fault.)
re: MPEG Streamclip - what a great app, eh? -
Rumple:
yeah, I think it has to do with M$ DRM moreso than
just being "picky" about which app plays what.
And M$ won't let them over that hump
( especially since '06 looks to be the start of
the "Battle for the Living Room" between
M$ and Apple).
and yes, MPEGStreamclip has become a
"can't live without" app, at getting stuff done
and out the door."Everyone has to learn, so that they can one day teach."
Urban Mac User
Which freeware (or paid tool) to cut easily HD movies (MOV,MTS)in 2 pieces?
By innovator in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 05:16 -
Hi ! How can I cut a portion from a video,and paste it to another?
By nightshift in forum EditingReplies: 20Last Post: 21st Nov 2010, 01:15 -
Joining abr vbr cbr audio videos (maybe cut/paste too)
By ZZen in forum EditingReplies: 2Last Post: 29th Jun 2009, 09:26 -
Thermal paste...
By kenmo in forum ComputerReplies: 16Last Post: 3rd Apr 2009, 21:08 -
How to "cut and paste" sections from different DVDs on one
By avz10 in forum Newbie / General discussionsReplies: 3Last Post: 28th Nov 2007, 13:41
