I just upgraded to "fair use wizard Ver 2". Before I was using Version 1 without any problems. Now I find that after converting a movie there is a slighty different file structure. The old version used to create a 700+ kb avi file which I burnt onto a DVD. Now the avi file is only 12kb with 3 FUD files and a project file and a text file. Is this normal, if so what do I burn onto the DVD.
Sorry if this is an old post.
MFM
It sounds like it didn't finish correctly and left you with working files.
Go to the Official support forums for FUW and you will find that this is a known problem, and that upgrading to 2.3LE seems to fix it. Head there and do some reading.Read my blog here.
Why Isn't Fair Use Wizard Extracting Subtitles?
By jdanniel in forum SubtitleReplies: 3Last Post: 9th Mar 2012, 12:49 -
Question about choosing resolution with Fair Use Wizard
By jimdagys in forum DVD RippingReplies: 2Last Post: 7th Jun 2010, 03:36 -
Updating the encoders bundled with Fair Use Wizard 2.8
By wkrick in forum DVD RippingReplies: 0Last Post: 19th Feb 2009, 15:31 -
Problem with Fair Use Wizard 2.8 Pro
By rreadysetno in forum DVD RippingReplies: 0Last Post: 3rd Oct 2008, 12:21 -
question about settings on Fair Use Wizard for best picture
By jimdagys in forum DVD RippingReplies: 4Last Post: 18th Oct 2007, 03:13
