A 2 part AVI that I was able to run on QT 7.0.2 once I had thrown the AC3 codec into Library.
So I tried burning it with Toast 7.0.1 in the data tab, and the playback shows great quality picture but no sound. Can Toast support unknown audio tracks?
It wasn't recognised when I checked the info in QT.
Any suggestions that are user-friendly to get the audio onto the DVD as well?
Have scanned the forum but couldn't find anything relevant.
TA.
you need QT v7.0.4. QT 7.0.2 broke this... the AC3 codec is variable bit and QT broke all VBR codecs.
get v7.0.4 of QT
get http://www.versiontracker.com/dyn/moreinfo/macosx/22994
should work just fine then -
It would be great if the update to QuickTime 7.0.4 solves the problem to the users' satisfaction. I'm just curious if there's a different solution based on massaging the .avi to turn it into either elementary streams, or a .mov file with .aiff or .mp2 sound? If I were taking that approach, I might use tools like MPEG Streamclip, QuickTime Pro, mAC3dec, and BitViceHelper.
I believe Streamclip and mAC3dec have their own AC3 decoders which are not based on QuickTime. If you give Toast something with .aiff or .mp2 sound, the burned files might be playable on more Macs.
What video codec does this particular AVI use? (Like .mov, .avi is just a container. To know what's going on with the video, you have to know the codec.)
-Pianoman
Burning AVI to DVD - AVI not viewable
By Budfudder in forum Video ConversionReplies: 8Last Post: 24th Mar 2011, 10:36 -
Burning a AVI file onto a DVD, but there's No Audio--Need Help
By PacMan3000 in forum AudioReplies: 3Last Post: 4th Jul 2009, 18:03 -
Burning .avi to DVD
By monieeka in forum MacReplies: 6Last Post: 12th Sep 2008, 07:40 -
Burning .avi with AC3 audio on Mac
By Munitalpa in forum MacReplies: 3Last Post: 22nd Aug 2007, 02:18 -
choppy video/audio in AVI to DVD burning
By spanish in forum Authoring (DVD)Replies: 4Last Post: 15th May 2007, 14:10
