I have a half-dozen files in the RealAudio RM format that I'd like to convert to MP3 to listen to offline. Been searching Google for a converter but all the one's I've found are restricted shareware costing around $20-30. Just doesn't seem to me that it's worth paying that for some program I may use a few times and then never again. Anyone know of a good freeware or open source program that will do the same thing?
Like a flea circus at a dog show!
http://rawavrecorder.homestead.com/
Its a real time encoder , so it will take the duration of your files to convert them . The site instructions say to install Real Player , I have Real Alternative installed and it works fine . Nowadays I use a plugin for Nero that will convert them instead (which is also free) but you need to have bought Nero of course . -
Google for RA2WAV. It's freeware and once you have the files as WAV you can then convert to MP3 (although I've a feeling that the latest version can go straight to MP3).
Free program to convert my cd's to mp3's?
By scustalow in forum AudioReplies: 15Last Post: 18th May 2011, 08:26 -
get a free dvd to mp3 converter
By lipton86 in forum AudioReplies: 9Last Post: 3rd May 2011, 21:11 -
Can someone recommend a free mp3 cd-r burning software?
By Huh...What? in forum ComputerReplies: 6Last Post: 25th Mar 2010, 09:30
