So I would like to build a menu and chapters with my own name, for my VCD to play in my DVD player.
I make my MPEG file, from Video Camera, and I would like to transfer my movie to DVD.
Please help me with idea, and I will greatly apreciate this![]()
icevideo,
Although I am not interested in making DVD and have much xperience on the topic. I could only refer you to use a program call DVDit. I tried it once, it does create menus and chapters. Jordan -
Sorry, typo problem. Its not that I have much but I DON'T have much xperience on the topic. Jordan
Nero menus are not correctly authored and you can't make chapters with it either.
I strongly suggest you use VCDImager +/- a GUI (e.g., TSCV or VCD Easy). A GUI like TSCV will help simplify the task greatly and is excellent for the beginner. If you search for it in the forums, you will find links to download as well as guides.
If you want to venture into authoring your VCDs manually (the most flexible and powerful way of authoring VCDs) try this: http://www.geocities.com/medinotes/vcd
Regards.
Michael Tam
w: Morsels of Evidence
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Looking For Software to Create Menu- w/ Fade Transitions Between Chapters
By restmin in forum Authoring (DVD)Replies: 2Last Post: 13th Apr 2011, 17:36 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36 -
Need to create video DVD with menu & chapters from VOBs. Any suggestion
By mr_tinka in forum Authoring (DVD)Replies: 2Last Post: 4th Feb 2008, 17:26 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
