I've had the Canopus ADVC 100 for a couple of years, and it's been pretty flawless in terms of the audio/video synch, which is what caused me to buy it in the first place. I use it wit SC-Live.
Every once in a while (and last night for hours!) the audio simply does not work. That is - I play my video source into the Canopus, and then into my PC via firewire, and then into SC-Live, but there is no audio. If I reboot the PC, restart SC-Live, and power-cycle the ADVC 100 (in no particular order!) all usually works fine, and life goes on. But last night, I rebooted several times, restarted the program a few times, powered the device on / off a few times ... all to no avail. Eventually, for no particularly good reason, it started working again.
I seem to remember seeing other posts to this effect in the past, but can't find them now by searching.
All I'm looking for is a 'sequence' to go through to bring the audio back to life - maybe there is a trick I'm not hitting upon!
Thanks!
I haven't seen that problem on mine but to troubleshoot I'd first try a different DV program and next I'd try the ADVC on a different computer.
There have been times when the ADVC locks up and needs a power cycle.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 15:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 14:21 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
