Results 1 to 12 of 12
    Dec 2002
    Misawa Japan
    I am trying to use the aforementioned program to convert my captured .tp files into a format I can then convert to WMVHD. I go through software and get rid of the commercials. When I then try to process the video the output of the program (the mpg files) have no video or audio but are still very large files. How can I fix this?
  2. I suspect whatever software you're using to edit the MPEG2 files can't handle the large frame size. You can try using an AVISynth script to open the MPEG2 (or tp) files and resize them. Or VirtualDubMPEG2 or VirtualDubMod if you want a more interactive environment.
    Dec 2002
    Misawa Japan
    I use videolan to play back the ts files and that works, so why wouldn't it work with the converted mpeg?
  4. Originally Posted by fearmyrage
    Because different programs have different abilities. I believe VLC has it's own built-in MPEG2 decoder and was designed to handle HD content. Many MPEG2 decoders are designed for SD content only.
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I expect it is a issue with your conversion process. If the converted file won't even play on your pc, then it sounds like the files are corrupt/invalid.
    Google is your Friend
  6. Where can i get the sourcecode of HDTVtoMPEG2_1.11.83?
  7. The mpeg2 file that i converted has no audio. I want to debug this problem,where can i get the HDTVtoMPEG2_1.11.83 sourcecode?
  8. Member Soopafresh's Avatar
    Jan 2004
    You can use ProjectX to convert your TS file to Mpeg2, then use MPG2CUT2 to remove commercials. Works very well.
  9. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    If you have a HD MPeg2_TS and it is playable, what is your reason for wanting conversion to WMV-HD?
    Getting that extra compression will take extremely long processing times. I'm just trying to understand your goals.
    http://www.kiva.org/about
  10. I download the projectx with java(27M),and setup it.
    when i run projectx.exe,error information is:"Exception occured during initialization" .what can i do for this.
  11. Member Soopafresh's Avatar
    Jan 2004
    That's strange. Works perfectly for most What version of Windows are you running ?
    That's the only error message ?"Exception occured during initialization" ? Any more specific error info ?
    Only other thing I can think of is perhaps you have JAVA installed already? Maybe the two versions are conflicting. Go directly into the c:\Program Files\ProjectxV0903 (or whatever it is called) and run ProjectX.exe directly from there.
    Last things to try: 1) Delete the projectX.ini file from the directory and retry 2) Uninstall, delete any files that remain in that folder, then reinstall.
    Good luck.
    Dec 2002
    Misawa Japan
    Ok now I can get HDTV2MPEG to work right but the output file can't be skipped through. I can only play it linerally. Also Windows media encoder can't open it, and tmepg xpress says there is no audio even though it plays finr in windows media player.
