I have two movies in VIDEO_TS folders containing .VOB .IFO they are in svcd format. Any way of converting for dvd without too much loss in quality?
PEACE
“He who makes a beast of himself gets rid of the pain of being a man.”
Try burning them to disc as they are and see if they will play. Assuming your stand alone will play SVCD, there is no conversion needed.
Google is your Friend -
Thanks KRISPY KRITTER,
I may have to try this but I really wanted both of them on one disc and tried to use TMPGENC dvd author, Thats when I found out I had encoded for SVCD not DVD. The files where originally in .BIN and .CUE and I used Badgersoft's SVCD2DVD and got back SVCD resolution (used wrong settings somewhere). Also my standalone makes a real racket when playing SVCD so would prefer DVD but.... -
There are a few guides on combining and converting SVCD to DVD, and you should be able to use your new files or the originals.
I'll post back and tell you how i got on.
Convert VOB files to Divx with DVD menu
By xtof in forum Video ConversionReplies: 1Last Post: 1st Mar 2011, 15:29 -
How to convert .vob files to a adjustable format?
By PurpleHaze22 in forum Video ConversionReplies: 24Last Post: 15th Nov 2010, 13:25 -
Convert .vob to another format with max quality
By alexv305 in forum DVD RippingReplies: 7Last Post: 19th Jun 2010, 22:36 -
Convert MTS files to DVD or BLU RAY format
By flix in forum Video ConversionReplies: 4Last Post: 21st Apr 2010, 21:03 -
Convert videos from .VOB format to MPEG?
By hawkeyed76 in forum MacReplies: 5Last Post: 10th Sep 2007, 01:10
