Hello everyone!
I'm experiencing this very wierd problem..
after demuxing a dvd, as a first step to adding a new subtitle later,
the audio and video files doesn't match!
the audio comes 2-4 seconds before the video.
I've tried doing this with 3 different softwares and the problem is standing still.
Please your help...
Thanks alot in advance,
Ashi.
P.S.
I'm a newbiw here so i wasn't sure in which forum i should have post this..
if this is not the right one please notice me..
Many of the tools (DGIndex, Rejig, Pgcdemux etc will give you a delay figure -- some offer to cure prob by padding audio length. Only caution is to be consistant -- don't check delay with one prog, then demux with another. Audio apps like delaycut will also pad the audio, or just set the delay in DVD authoring app. or something like V/Dub if rendering there.
Well thanks!Originally Posted by mikiem
but your message is a bit too general for a newbie as me..
Can you please recommend me exactly what to do?
many thanks in advance!
Ashi.
subtitles 25fps, video 24fps both synchronized - converting to DVD, a mess
By Ze Tomes in forum SubtitleReplies: 10Last Post: 27th May 2011, 01:45 -
extraction synchronized with video
By amandioc1 in forum Capturing and VCRReplies: 2Last Post: 29th May 2010, 05:38 -
The audio and video aren't syncronozed
By orfajackson in forum Newbie / General discussionsReplies: 3Last Post: 6th Jul 2009, 02:56 -
Extracting/demuxing a .TS into separate video and audio files?
By mkvbob in forum DVB / IPTVReplies: 10Last Post: 25th Jul 2008, 03:15 -
playing mkv - Audio is not synchronized with video
By Shasoosh in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jul 2007, 12:26
