Are these available?
I can't find any.
Any help would be great!!
Ken
A web search turned up nothing, making me think that they aren't available yet. You might be interested in the following comment which I have copied from another forum. It has reduced my interest in this format to next to almost zero.
"Since the RW media use a phase-change material which have a much higher absorption than the dyes in write-once discs, it would not be possible to design a DVD rewritable dual-layer system that complies to the DVD standard, which requires a 18% reflectivity. As a result, the DVD+RW DL media would not be compatible with current DVD players, and a hardware upgrade (not firmware) would be an essential before using it. "
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Is there such a thing as DVD-RW DL disks?
By the_importer in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Dec 2007, 05:28 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
Where to get DVD DL disks cheap?
By Jorge in forum DVD RippingReplies: 44Last Post: 21st Sep 2007, 10:38 -
Toshiba A2 and DVD-R disks
By Prot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Jul 2007, 19:28
