i got a movie file that has dual language playing at the same time, how do i set the movie so that it only outputs one language?
What kind of movie?
Probably, it's a matter of turning the speaker balance fully left or fully right.
/Mats -
Or more specifically, WHICH PLAYER are you using? Sometimes, it's the matter of getting a better player.
I've seen a few Chinese VCDs like that. (Cantonese on one channel and Mandarin on the other channel.) Hopefully the file you have isn't a mono mix. If it is, there is nothing you can do.
Sounds like whoever encoded it from VCD didn't bother to separate the tracks. Lousy *******s.
Use the mixer and turn balance all to the way to left or right. -
On most DVD players, the [AUDIO] stream change feature has 2 different modes of operation.
1-DVD (and possibly SVCD) mode: pressing [AUDIO] changes the stream/language encoded (from 1 up to possibly 8 on DVD, up to possibly 4 on SVCD)
2-VCD/CDDA mode: pressing [AUDIO] changes the output from Stereo to Mono to LeftOnly to RightOnly
Does your player work differently?
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 18:34 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 17:46 -
single audio play right through menus + highlighting selection
By Rudyard in forum Authoring (DVD)Replies: 4Last Post: 15th Nov 2008, 23:16 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29 -
Converting Bi-Lingual VCDs to Single Language MPEGs
By HHBear in forum Video ConversionReplies: 3Last Post: 13th Feb 2008, 23:05
