Hi all i encoded a few mpegs files using mainconcept mpeg encoder and now i imported it to adobe encorde dvd . But when i drag over menu to make buttons out it it freezes and i have to close the program!! Could any one tell me what is wrong here?I few days ago i worked with some short avi files and it worked well but with these mpegs i have poblem. Thanks
Adobe video editors are not great for MPEG editing. Try MPEG Video Wizard.
Originally Posted by pchan
Thank u for u reply. well i am not trying to edit mpeg file. All i want to do is to burn a few mpegs files to a dvd using adobe encore dvd. I tried a few small avi files and it did not give me any problem.Well i am suprised to hear you saying adobe prmier pro is bad editting too if u are refering to that tooll!! -
Sounds to me like Encore's having prob reading the files, prob locking from an incompatibility issue or two -- anyway, IMHO
If Encore tries to use a certain set of files to decode the video, and it can't find what it's after in those files, then it can lock.
Usually I've seen this sort of thing when files are changed to other versions, or other versions are registered as default with Windows. As Adobe uses Mainconcept (AFAIK), & since using another mainconcept app, I'd check there 1st, re-registering *Adobe's* mainconcept files, or just reinstalling Encore.
Or could temporarily rename Adobe version Mainconcept files, or the separate encoder versions instead. And check for other mpg2 decoders on your system, renaming those files temporarily.
Importing VOBs in Adobe PremierPro CS5
By LiaP in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2010, 14:55 -
(update)Importing .mkv to Adobe Premiere CS4
By yodnnee in forum EditingReplies: 1Last Post: 23rd Jan 2010, 08:58 -
Problem importing Russian subtitles into Adobe Encore
By adanepst1 in forum SubtitleReplies: 2Last Post: 29th Jan 2009, 13:12 -
Importing/Editing Video with Adobe Premier 6
By Namrepus221 in forum EditingReplies: 10Last Post: 12th May 2008, 21:30 -
adobe cs3 conforming when importing mpegs
By themoog in forum Newbie / General discussionsReplies: 0Last Post: 23rd Nov 2007, 12:28
