I converted to VCD using TMPGEnc but the picture is so skinny. How do I make it so that it like the original DVD screen?
first, determine your source aspect ratio. it should be stated in dvd2avi. also, for image positioning or something like that choose fit to frame (preserve aspect ratio) and for later versions of tmpgenc choose full screen (preserve aspect ratio)
I understand there must be the source asptect ratio. But how do I select the right radio from the original movie ? I there way I can check from the vob file and how do I go about it from the DVD2AVI?
hailieu,
under dvd2avi->file->open
there you can select the vob files to open. once you opened the vob files, press f5. an info menu will pop up; it will tell you the source aspect ratio, frame rate, and video type (i.e. interlaced or progressive).
how can i removed crop with winff and make full screen
By phoenixa in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2012, 03:48 -
how can i make full screen to my philips gogear vibe?
By phoenixa in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2012, 11:01 -
Screen doesn't expand to the max of the HDTV width and height.
By wishstar99 in forum ComputerReplies: 11Last Post: 30th Aug 2010, 11:08 -
A way to auto-make screen caps from videos?
By Scav2003 in forum MacReplies: 15Last Post: 20th Aug 2010, 00:05 -
how to make dvd that does not fill up the screen!
By turbochargedRS in forum Authoring (DVD)Replies: 13Last Post: 20th Jun 2008, 23:37
