hello everyone i got a few avis i want to put onto a dvd and am wondering how do i import the menu i used to make my first dvd,can it be done thanks![]()
If you want to use a certain menu or menu layout for more then one project, easiest way is to create and save templates in your authoring prog.
It's not hard to pull the pictures and stuff out that you used & then re-create the menu -- just like demuxing rest of video with several guides and tools.
Re-using menus can be done with Pgcedit, but there's a little bit of a learning curve, or VobBlanker will let you take your original DVD on your hard drive, and replace the content with your new stuff. Again there are a few guides to get you started.
Might also look at prog like Redo. -
ok how do i just ripp the menu from the disk to use as a template for my next movie
DVD Flick importing jpg/bmp
By Soixante in forum Authoring (DVD)Replies: 2Last Post: 19th Sep 2009, 15:19 -
Questions about DVD importing and menu creation
By Reading Bug in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2009, 16:24 -
Importing menu transitions from a DVD to another with DVDLab Pro
By lorix in forum Authoring (DVD)Replies: 7Last Post: 6th Nov 2008, 13:52 -
importing a DVD into VEGAS Studio
By lissow in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2008, 02:34 -
Importing subtitles into DVD Architect 4.0
By hurricane1951 in forum SubtitleReplies: 3Last Post: 14th Apr 2008, 17:44
