Hi....
i have many original dvd, but in some i dont have some language that i want and in others i cant change directly the language (voice) but i have to go through start menu.
Questions:
1) WHere i can find orginal subtitles (legals) to use for my DVD?
2) Which is the most easy way to insert subtitles inside dvd (i found many different guides in this site)?
3) How can i adjust the "problem" that in some dvd i cant switch from a languae to another?
I hope i could explain my problems in a right way
Many thanks to all
Alex (Rome)
There are subs for divx on the net if you want to convert to divx & then add subs.
"How can i adjust the "problem" that in some dvd i cant switch from a languae to another? "
Probably just need to remove *Prohibited User OPerations" by ripping DVD & re-burning, or maybe check out something like AnyDVD, if it removes these restrictions as well with your originals.
"1) WHere i can find orginal subtitles (legals) to use for my DVD?
2) Which is the most easy way to insert subtitles inside dvd (i found many different guides in this site)? "
Strictly speaking, Have NO idea on the legal aspects. If somebodies stripped the subs out for a language that you want, or if you can get your hands on a DVD with those subs to rip them out yourself, It's not hard at all to insert them in the DVD layout. One of many guides I personally like involves creating new vobs with muxman, then replacing the existing ones using VobBlanker. If you have text subs, then have to render them 1st. You might look at DVDSubEdit in case you need to adjust tming, or Subtitle Workshop if text-based.
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Questions about few things. DVD to Divx with permanent subtitles, etc
By Earthling2000 in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2009, 13:15 -
Add subtitles to dvd menu - core questions
By Arcanis01 in forum Newbie / General discussionsReplies: 3Last Post: 26th Nov 2008, 15:46 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08
