I've got this weird problem when playing a XviD encoded movie I got from a friend. He can view it with no problems.
I really don't have a clue. VirtualDub gives me an error in decompressing frames, while the movie actually plays in WMP
but yhe image looks damn weird (see pictures)
I already installed the latest XviD codec and the problem remains the same.
AVI codec details about the file:
File : 698 MB (698 MB), duration: 1:52:57, type: AVI, 1 audio stream(s), quality: 42 %
Video : 653 MB, 808 Kbps, 23.976 fps, 692*448 (4:3), XVID = XVID Mpeg-4, Supported
Audio : 45 MB, 56 Kbps, 24000 Hz, 1 channels, 0x55 = Lame MP3, Supported
The intro, this should be a circle...
And here we should see a man standing...
I don't know if this is the right place, I hope it
Any hint or tips are welcome, since I really need this file, as it is part of a course we're following.
tnx!
try play with vlc media player, it has built in xvid codecs.
Well it works!Originally Posted by Baldrick
Many thanks man! Although I still wonder what's rotten with my 'normal' installed XviD codec, anyway it's working
Try going to the Xvid decoder config and changing the Output Colourspace setting.
Hi-
The problem initially was that the width is only Mod4 (divisible by 4), whereas it should be at least Mod8 and better would be Mod16. A lot of graphics cards can't handle Mod4 resolutions well and produce output like your pictures. Also, the original encoder was an idiot, because in addition to making that rookie mistake, he most likely didn't resize properly, as it's 1.54:1, and probably doesn't play with correct Aspect Ratio. My guess is that circle is an oval, even after VLC plays it properly. The resolution is too high for decent quality, and no self-respecting encoder would give it that audio. -
Well I have to admit, the video quality is idd very poor, and so is the audio.
But I don't really care, it needed to fit on one CD and it's just a guy talking on a stage, so I don't really need good video or audio quality like you would for a movie...
In fact, the audio quality is just fine for just a voice
He probably used some shitty program
video freezes quixkly / slanted lines
By sturoc in forum Newbie / General discussionsReplies: 11Last Post: 24th Aug 2011, 09:29 -
How to show a person walking as slanted ?
By gseshwar in forum Newbie / General discussionsReplies: 8Last Post: 16th Jul 2011, 13:12 -
took video of someone, but it's slanted. How do i straigten it out?
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 12th Sep 2010, 07:25 -
Source image format is not acceptable (VDMOD, XVID, AC3)
By stlolth in forum Video ConversionReplies: 8Last Post: 23rd Aug 2010, 10:22 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29
