I've been ripping DVD's for the last week and have had no problem with VCD's but when I encode a SVCD it usually cuts the last few minutes of the movie off. The last one cut about 25 minutes off of the end of the movie, which was Score. Any clues on how to fix this problem? I have followed the instructions down to the T and my settings are the same as the ones used by Sefy's example. Any help would be appreciated.
Sometimes following to the T is not that good, cause you miss all the way to Z, what I mean is, the Guide should be used as an Example, not to set everything to the T according to the guide.
Like some people used the exact number in the Source Range as in my guide, but they used it for other movies, and each movie is of diffrent length and diffrent settings, settings to the T is not the correct way, you need to follow the guide as an example, and set everything according to YOUR movie.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
x.264 intraframe compression and short GOP encoding
By anonymous_whatever in forum Newbie / General discussionsReplies: 20Last Post: 15th Feb 2012, 12:48 -
VideoRedo cutting short?
By chronic777 in forum EditingReplies: 3Last Post: 23rd Jul 2008, 16:07 -
TMPGEnc DVD Author 1.6 cutting a movie short?
By FizzFozz in forum Newbie / General discussionsReplies: 0Last Post: 21st Jun 2008, 11:20 -
Cutting a short clip from a DVD
By Nutmeg7 in forum MacReplies: 1Last Post: 13th Nov 2007, 22:58 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 15:37
