I ripped a friends homemade dvd and tried to convert it to avi using AutoGK, but everytime I try it it gets stuck on a single frame while in "Analyzing Source" mode. Is there anyway I can skip that certain frame and get this conversion done, or any other tool that can help me out? I tried installing avi.net but it wouldn't even launch after I installed it and give me an error message everytime.
any input?
Hi mehdihs,
1) Rip to PC as one single VOB. I can't remember which ripper(s) do(es) this, but it can be done. Have a look around.
2) Load the VOB into VirtualDubMod and set that app to use your desired codec (Divx, Xvid, DV AVI). I've only ever done this using the Panasonic DV AVI codec, but it worked excellently.
I'm presuming it'll work with other codecs.
3) Save out as AVI.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
DVDDecrypter can be set to rip to one VOB. But I have a feeling, that isn't a solution in this case - We have to deal with the source VOB(s) we have, right?
/Mats -
Yes the problem is with the source VOBs. I tried merging all the vobs into one to see if that works but it doesn't. Its an issue with a single frame. Is there no way to neglect that frame?
Try loading the merged VOB in VirtualDubMod, and cut out the trouble spot, and encode to AVI
/Mats -
It finished the DG index part fine. It just gets stuck on the next step when it starts vitrualdubMod.
Frame-By-Frame Restored James Bond Films Released
By Soopafresh in forum RestorationReplies: 9Last Post: 27th Apr 2012, 14:09 -
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
WMP and VB6, is it possible to step forward or back frame by frame?
By gadgetguy in forum ProgrammingReplies: 11Last Post: 6th Mar 2009, 20:00 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53
