  1. Member geddeth's Avatar
    Feb 2005
    Denmark
    I'm converting home-shot DVD footage from a Sony DVD Handycam (mini-DVDs) for editing. I'm attempting to get the best quality single-video file to work with, since I can't use VOBs directly in my video editing software. There are other considerations though, so please bear with me:
    In short, these are my considerations, top priorities first:
    1. Compatibility - needs to be playable on any Win2K-system without any codecs installed, and editable in video software (Adobe) - xvid etc. tends not to be in my experience
    2. Quality - best quality available with the codecs at hand (see source footage specs below)
    3. Compression speed - shouldn't take days to compress a 1.4GB miniDVD
    4. Filesize - least of my worries
    Specs of source material:
    Media: 1.4GB miniDVD
    Container: MPEG-2
    Audio: AC3 48000Hz 256kb/s total, 2 channels, CBR
    Video: Frame 704x576, SDE 720x576, FAR 1.222, PAR 1.091, DAR 4:3, ~9300kbps, PAL, 25 fps, interlaced, top field first
    So far, I've been using VirtualDub-MPEG2 for compressing the VOBs to AVI using Lame MP3 320kbps and Intel Indeo 5.1 at Quality 100 and keyframes every 25 frames. I also use the built-in deinterlace filter in blend mode on each VOB.
    I find that the video becomes grainy at times and the sound quality ranges from mediocre to downright cr*p. I'm not sure what it is in the source material that causes this to happen.
    Can I do this better in any way?
    Cheers,
    Geddeth
    Extract VOB out to uncompressed AVI with WAV/PCM audio. No loss from the MPEG this way. VirtualDub that can open MPEG is the correct tool for this job.
    Open in your video editor. I use Adobe Premiere.
    Edit as desired, then export from editor to MPEG encoder. I use Adobe MPEG Encoder or Procoder MPEG plugin.
    Author DVD in software of choice. I create menu images in Photoshop. I author and compile menus in Ulead DVD Workshoip 2.
    Output is professional quality work.
    Very streamlined and simple process, not a lot of codecs or software or settings or other such rot. The only requirement is plenty of hard drive space. I have 1TB.
    If uncompressed video is too large, consider using the free HuffYUV codec, or maybe the free Adaptec DVSoft codec (DV stream, 13 GB/hour). Or you could always add another hard drive. If you're doing lots of work and quality is priority #1, get the drive, a nice 250GB or larger (Ultra ATA expansion card, or serial ATA motherboard, may be required).
    And don't ask for "best". Ask for a "good method" or "help on improving". "Best" is ridiculed around here, and quite rightly so.
    edited for spelling, as usual
  3. Member geddeth's Avatar
    Feb 2005
    Denmark
    Roger on the 'best' part. There is obviously no such thing.
    Will think about the other recommendations and return. Thanks for the swift reply!
