is there way i can make my Pioneer DV-444 region free cheaply.
is there any software that will rewrite player to make it region free
i bought it used so i dont want to spend any more if i can help it.
little short of cash at the mo.
more than likely,youll need to chip it.
why not use the links to the left
<------------------ simple to use!!
that way you can look at the hacks for it,and see,it needs chipped and IMO,isnt worth it.
easier to make a backup of the disc you want to view,keeping the original safe.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
ReQ: Toshiba DVR20KB Multi-Region Hack
By Teac23 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Aug 2010, 05:14 -
Region free hack/code for pioneer XV-HTD520?
By efirtion in forum DVD & Blu-ray PlayersReplies: 2Last Post: 11th Dec 2007, 12:21 -
REQ'ED ----> region free hack for "speler dvd player, model: spdv-4
By pedomenoide in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Aug 2007, 13:41 -
Pioneer DVR K-17 Region Hack
By d1sc0_dave in forum DVD & Blu-ray PlayersReplies: 0Last Post: 29th Jun 2007, 17:46 -
Looking for region hack for Pioneer DV-79AVi
By yanckoff in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Jun 2007, 13:34
