I have tried the sound cand on the mother board and installed a direct card
The line in is activated and the sound from the vhs tape is clean and volume controlled .
I have 3 different capture programs , all show the picture and sound is working
Press capture and all looks good.
try and play back and always no sound. not a bip
The small windows program sound recorder will record the sound
but no capture program
What have I done wrong ?
And the Windows RECORD Mixer has the Line-In checked?
Can you record the Line-In with an audio application and have it work? -
SOme capture hardware need to have the audio plugged into it, which it then passes on to sound card?
It all depends on what hardware/software you are using. There are preferences/options/settings in various softwares where you have to select where to capture the sound from. Lets start by you telling us what hardware/software you are trying to use?
Rob -
the sound is direct from the vhhs recorder to the cound card line in
the sound card is set to line is and the sound is coming in OK
the captuer programs (3) all do the same capture the video and not the sound , yet the sound is in the preview screen as is the video
I can capture the sound from the vhs via the windows record small program
this is nuts as it worked before the crash of windows -
If nothing in hardware is broken then it has to be the Windows mixer not letting you use the line in.
Try opening the Windows mixer with the Record window open and start your recording application and see if it switches to another input.
Sound wont work on KWORLD DVD Maker USB 2.0
By BiggerJim in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2014, 06:06 -
MPC wont play sound when watching DVD
By Anonymous1 in forum Software PlayingReplies: 1Last Post: 18th Oct 2011, 07:52 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 14:55 -
the sound in my converted videos IS there, but some programs wont play it?
By extent in forum Video ConversionReplies: 8Last Post: 30th Aug 2010, 16:38 -
How to save the "Plug In Chainer" in Sound Forge 9.0
By mlong30 in forum AudioReplies: 1Last Post: 14th Jun 2009, 04:13
