  1. Member Prot's Avatar
    Dec 2003
    Oregon
    Ok, all you SQL and MySQL experts. I have a question.
    I need an SQL command to display only the results that return a NULL value. I know I need to use a LEFT JOIN command, but I'm getting all the results, NULLS included.
    This is the command I have:
    SELECT FLNAME, CLTERM, CLYEAR
    FROM tblFaculty F LEFT JOIN tblCLasses C
    ON F.FNUM=C.FNUM
    FLName appears in tblFaculty and CLTERM and CLYEAR are in tblClasses.
    I need to display results where F.Num has no corresponding value to C.FNum. Any Ideas? I'm missing something in my command.
    thanks
    TANSTAAFL
    Nov 2002
    ON F.FNUM=C.FNUM
    thanks
    How about a subquery?
    FROM tblFalculty F, tblClasses C
    where F.FNUM NOT IN
    (Select FNUM from tblClasses)
  3. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Check your PM.
    Try:
    SELECT F.FLNAME, C.CLTERM, C.CLYEAR
    FROM tblFaculty F, tblCLasses C
    WHERE F.FNUM=C.FNUM(+)
  4. Member Prot's Avatar
    Dec 2003
    Oregon
    Originally Posted by tekkieman
    Check your PM.
    Try:
    I tried that, tekkieman. I should say I have to do this SQL command in Access, and Access does not like the (+).
    This query is going to be a 1 to none, and I did not take notes like I should have. Poor me
    Well, the assignment is not due until Wednesday, and I will see another student in the class in one of my other classes. Guess I could ask him. Otherwise I will just have to ask instructor tomorrow.
    Thanks for the replies.
    TANSTAAFL
  5. Member Prot's Avatar
    Dec 2003
    Oregon
    I found the answer on my own. All I needed was an additional statement.
    ON F.FNUM=C.FNUM
    WHERE CLTERM is NULL
    TANSTAAFL
  6. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    I would have suggested that, but for some reason I thought you had already put that in your original query. I could have sworn I saw that WHERE CLTERM is NULL line already.
    Nov 2002
    SQL is at times quite counterintuitive, since it's kinda read "backwards".
    Jul 2002
    Up in yo' bitch.
    Dammit!!! The one question I could've answered and I miss it! Stupid knowing SQL!
