I was wondering if it were possible if I had a video of a person talking to someone and then a video of myself to replace my head over the head of the person in the first video.
E.g. In a still photo, I would just cut out the other head and replace it with a cutout of my head. Simple.
But in video I am not sure if its that easy.
I dont need a proffesional end result (unless thats just as easy!) its kind of a joke thing so any result I guess is better than none.
I have access to premier pro, vegas, ulead video studio and obviously any free utilities on the net.
Thankyou for any help.
Results 1 to 10 of 10
Ok, so am I to assume its not anything at all like doing it with a still picture and I should give up?
No the video doesnt have a heap of motion and yes I am happy with rough edges. Its actually just a clip from the 'this is your life show' and the person is sitting on the couch. I just want to stick my head over the persons.Originally Posted by guns1inger
Could you please point me to a guide or explain how I would do it using keyframes? -
you have my interest as well....how an this be done in the "quick and dirty" fashion?
Maybe this guy can offer some suggestions. (Click Here)
Buy My Books -
In Prem Pro, import your original footage.
Then import your overlay gag footage. (video2 layer)
crop this footage down to the head and shift to the right location (for a rough image)
or wear the green t-shirt against the green background (only has to be a head shot (or cropped later to head shot) then reduced in size on the timeline and given the chroma key/ green screen effect.
You'll need to do the reading in prem pro files for the finer points. -
If the head you want to overlay is just a still, then you only need to cut the head out of the picture in your image editor like Photoshop or Gimp and save as a PSD or PNG with transparent layer. Import it into Premiere Pro (it will auto detect alpha chanel) and insert it in the track above your video clip. Then use the Resize, Rotate and Motion filters in the effects pallet to position size and rotate to keep up with the movement.
If you want a head that is talking and such, you'll probably need to shoot in front of a Green Screen then Key out the Green background with the Croma Key filter in the Effects Pallet.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
Ok thanksgarry and dipstick - I think I can get it done like that.
Cheers for answering the pm call for help dipstick, it is appreciated.
Now to get to work!
Product for Putting a Head on an Animated Body?
By shira in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2011, 18:10 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Putting different types of file formats on to DVD-R
By carl606 in forum Newbie / General discussionsReplies: 10Last Post: 11th Mar 2010, 06:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Striping audio from DV file and putting new audio in?
By clownage in forum AudioReplies: 4Last Post: 5th Mar 2008, 10:19
