im tring to get my buttons to go down in order.
even if i do it in order it still skips. is there a way to fix this?
is there an option?
it goes 1 2 3 4 5 6 7 8 9 12 10 11
i got it set up like this.
EX:
[ options ]
[ back to main menu ] [resume movie]
[ play movie 1 ]
[ play movie 2 ]
[ play movie 3 ]
[ play movie 4 ]
[ play movie 5 ]
[ play movie 6 ]
[ play movie 7 ]
[ play movie 8 ]
[ play movie 9 ]
[ play movie 10 ]
[ play movie 11 ]
[ play movie 12 ]
with some dvd players my buttons are off.
i hit the "tv mode" button and it fixs the problem.
tv mode settings
1: wide 16:9 "in this mode the buttons are on"
2: normal/PS "in this mode the buttons are off"
3: normal/LB "in this mode the buttons are off"
is there a way to fix it to work with all 3 settings in DVD-lab PRO?
Hi dblue,
I'm still new to DVDLab Pro, and have struggled with a few things. If you don't get any / much luck here then I've found the help pages at the home site to be really good.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
By defualt, DVD Lab Pro auto-routes buttons, and not always successfully. You can turn this off and route manually if you wish. The button is on the tool bar and has little coloured arrows on it. (sorry about the vagueness, but I'm not in front of my home PC right now, so I can call DLP up to check)
Read my blog here.
You click the one icon up top in the menu window to turn off auto-routing, select one of 4 directions, then drag arrow lines from *Center* of one frame/bounding box to another. Repeat for other 3 directions.
As I remember it anyway, so please take with a couple of grains of salt.
More dvd lab questions
By sterankin in forum Authoring (DVD)Replies: 12Last Post: 16th Aug 2010, 17:13 -
DVD Lab Pro 2's Render Menu Motion - Intro and Loop Questions?
By xhonzi in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2009, 18:52 -
DVD Lab Pro
By Flying Doctor in forum Authoring (DVD)Replies: 6Last Post: 16th Jun 2008, 10:00 -
Help with DVD-lab pro
By Jack the Ripper in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 08:21 -
DVD Lab Pro - Three elemenetary "hot to ....." questions
By perfection in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 07:45
