i have a movie that is broken up into 6 parts and each part is zipped up using WinRAR. when i unzip the first part each part after that follows, so what i am left is a folder titled video_ts.... when i open this folder inside are little white squares with vod1 , vod2 and so on . how do i put this thing to gether to view this movie......any info would be great.![]()
Take a look to the upper left, 'What is' DVD. That will tell you the DVD format, part of which is the VIDEO_TS folder. If all the parts are there, you burn that to a DVD. If some are missing, a program like IFOEdit can replace them. The movie is in the VOB files, but the rest is required for the DVD structure.
I use Nero, selecting DVD-Video, then take those files in the VIDEO_TS folder, put them into the Nero VIDEO_TS folder and burn. -
Frankly, this falls outside the purview of this entire website.
If you're sure in in six parts, then you have to combine them into a single file first, THEN you can unRAR it properly. -
Actually, if they had 'rar'ed a VIDEO_TS folder and it's complete, WinRar should be able to put it all back together, though I've never seen that.
Putting Together Movie Clips
By SeaBird in forum EditingReplies: 1Last Post: 24th Mar 2012, 12:31 -
Putting photos in timeline and editing their length. Sony Movie Studio HD
By jjzapp in forum EditingReplies: 1Last Post: 4th May 2011, 22:37 -
DVDFABHD putting DVDFAB.com logo on movie
By MCnDaHouse in forum Blu-ray RippingReplies: 7Last Post: 28th Apr 2011, 20:55 -
Putting More Than One Movie On A DVD
By swordsman in forum Authoring (DVD)Replies: 1Last Post: 19th Sep 2007, 13:11 -
putting an mp4 movie on to a DVD.
By patrick_jimmy in forum Video ConversionReplies: 12Last Post: 20th Aug 2007, 02:49
