I have an idx and sub file which contains subtitles in three different languages. I would like to leave just the english subtitles in the idx/sub file and remove the other two languages. I would also like to change the colour of the remaining english subtitles. The idx/sub file is to be used for encoding permanent subtiles into an avi file using virtualdubmod in the subtitle colour of my choice. At the moment virtualdubmod uses the first subtitle stream that it came across which happened to be spanish and the default yellow subtitles!! Can anyone help me out with this please?
Hi-
To remove the 2 languages you don't want, open the IDX in VobSubStrip and remove the other 2. To change the colors, one way is to open the IDX in VobSub Configure (included as part of the VobSub package), check the "Custom Colors" box, click on the color, and change it to whatever you want.
You can find VobSubStrip here:
http://www.free-codecs.com/download/VobSubStrip.htm
Question how to edit sub/idx file
By jimdagys in forum SubtitleReplies: 6Last Post: 29th Jan 2013, 15:07 -
Question how to expand timing of sub/idx subtitle
By jimdagys in forum SubtitleReplies: 1Last Post: 10th Jun 2010, 08:30 -
question about IDX and SUB
By hilario in forum SubtitleReplies: 2Last Post: 14th Feb 2010, 04:30 -
idx/sub question
By picrade in forum SubtitleReplies: 1Last Post: 4th Jun 2008, 16:44 -
How to join the idx/sub languages ripped separatedly into just one idx/sub?
By Talayero in forum SubtitleReplies: 5Last Post: 29th Mar 2008, 08:58
