I have an mpeg (from TiVo) that is 480x480
What options should I choose here?
What do I put on this template. I am going to be putting the mpeg onto a dvd.
Also, if I plan on putting 2or3 of these mpegs on a dvd, should I convert them all as one, or individually?
Here is the info that dvd patcher gives me about the mpeg itself (just ignore the red numbers)
What We Do In Life, Echoes In Eternity....
1) None, it's entirely OPTIONAL
2) 480x480 is NOT a valid DVD video size. If you used the wizard, you should have picked one of the DVD templates, thus you wouldn't be asking this question.
I know 480x480 isn't dvd spec that is what my source is. (Tivo file). I'm trying to get this mpeg dvd compliant so I can watch it on my dvdplayer
What We Do In Life, Echoes In Eternity.... -
When I resize it, it'll make the one mpeg use all of the dvd space it can right? What if I want to put 3 of these files onto 1 dvd? How would I do that?
You use a bitrate calculator. Use the total running time of all the files and it will show you the bitrate to use to fill all of the disc. There are several in 'Tools'.
You can either adjust the bitrate or make the file size smaller here:
But I would use a DVD template instead.
Use dvdpatcher and set it for 352x480 and patch the file, load the patched file in your dvd auther program then patch the vob file(s) back to 480x480What do I put on this template. I am going to be putting the mpeg onto a dvd.
Convert the audio to 48000hz mp2/ac3/pcm if needed.
There is no reason to re-encode the video unless your dvd player is very fussy. -
I'll second the DVDPatcher method. It's faster and better quality than re-encoding. It won't work on all DVD players but it's worth a try.
Patch the headers to 352x480, author your DVD then patch the VOB's back to 480x480. Patch the entire file (not just the first header) and patch only the movie VOB and not the menus.
Works for me."Art is making something out of nothing and selling it." - Frank Zappa
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
Mkv avchd pointers
By romanticwarrior in forum Authoring (Blu-ray)Replies: 5Last Post: 7th Sep 2010, 17:57 -
tmpgenc 4 audio no AAC encoder?
By sychern in forum Video ConversionReplies: 1Last Post: 22nd Jun 2009, 21:06 -
Better encoder than TMPGEnc
By dazza555 in forum Video ConversionReplies: 7Last Post: 15th Sep 2007, 09:45 -
I need to buy a Quality RCA Audio cable, any pointers?
By faramith in forum AudioReplies: 7Last Post: 7th Jul 2007, 13:25
