Wondering if there are any sites that gives out the resolution and bitrate for each of their channels. I have had dishnet and wasn't satisfied with their premium channels so I switched to directv and have the same opinion.
Most of dish is 480x480. Direct is a bit higher. Both use WAY too much compression. Unless you want to go c-band, you are stuck with those choices.
Hi,
A friend of mine had this service (Dishnet) for some time and I notice that
video resolution was 544 X 480, apart from that, a massive amount of
macroblocks flying around when watching the picture in a computer screen.No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
mkv aac bitrate info missing
By codemaster in forum Video ConversionReplies: 1Last Post: 8th Dec 2010, 06:55 -
Bitrate info of MTS file
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 15th Oct 2009, 20:49 -
Audio bitrate info
By uniks in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2009, 16:50 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
Need some info on bitrate calculation
By heman28 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 19:18
