When I play my VCD in stand alone DVD/VCD player it looks like a blown up picture.Well I guess thats because it is.Play it on small screen on computer looks good blown up on big TV looks bad.
Any way to fix this?
Results 1 to 10 of 10
Nope, you can't reclaim the video that's already been discarded through compression and resizing.
You could always try re-encoding it with some filters to try and soften the video, but you would still be blowing it up way beyond the resolution and available video contained will allow. -
You can run it through some filters for sharpening and noise reduction, but no, you can't create quality out of nothing.
vcd and quality cannot be joined in the same sentence without a qualifier such as "terrible" or "horrible"
Originally Posted by greymalkin"Art is making something out of nothing and selling it." - Frank Zappa
See I was thinking that it was the resolution differance between my CO monitor and the TV that made it look bad.It looks alot better on my CO even after I convert,encode the file.And I thought when Its blown up on the TV and the TV had fewer pixels it lose detail.The picture basicaly looks the same as when you blow up a photo.It has that checkering effect.So I thought it could be fixed some how.The same as when they fix pictures.Thats just what I was thinking.
But what do I know Im new at this stuff.But Im having fun trying to figure it all out.
Some stuff I put on vcd turn out ok or as one person said "close to a home vhs".
Also Memorex CD-Rs are not any good for vcd burning. -
Originally Posted by kschang
You may have a black level problem, not a resolution issue. The dark parts of the video are black on the computer so you don't see the macroblocks there. On the TV the dark parts aren't completely black so you see the macroblocks.
This is bacause computer monitors have different gamma curves than television.
Newbie question about resolution and quality
By Sutekh in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2009, 18:01 -
I have a question how to get hd quality on a tuner
By sdavis in forum Capturing and VCRReplies: 5Last Post: 16th Dec 2008, 15:52 -
Video Quality Question
By Augie5390 in forum Video ConversionReplies: 24Last Post: 10th Oct 2008, 18:35 -
Question about Quality between I-P-B frame
By Starkian in forum Newbie / General discussionsReplies: 5Last Post: 12th Jul 2008, 01:52 -
DV to dvd quality question
By cd090580 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Nov 2007, 02:12
