Results 1 to 25 of 25
    Dec 2005
    I have the game starcraft and i wanna make a copy of it how would i do that... and i went to that gamecopyworld and they dont have the up to date one so i was wondering if theres a way 2 burn it manually. or somthing
    EDIT ***
    No-CD & Fixed Executables for this game are not available @ GameCopyWorld.
  2. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    You'll want to move your question to the "Newbie/General Discussion" forum. You'll get better help there.
  3. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    I think he asked in the right place for this site, since this is not a game site. But you might be better off going to a gaming site and asking there.
    Buy My Books
    Look here:
    http://www.cdrom-guide.com/forums
    http://forums.afterdawn.com/
    Go there for video games stuff.
    Dec 2005
    thnx
    Mar 2003
    go for some alcohol
    alcohol 120% that is
    Dec 2005
    i have it but how would this be witth that tho...
    Dec 2005
    tried making a copy in iso deff didint work lots of errors at 52%
    Read Disk Error
    Read Data Examination Error
    Same thing happened with NEro when i tried coping.. now what~
    Mar 2003
    Make a disk image with alcohol 120%
    Dec 2005
    Read Error Examination error it wont let me copy disk image :- \
    Mar 2003
    Does it actually quit or does it give you errors
    Try blindread
    Dec 2005
    just lots of different erros and i will try that
    Dec 2005
    Nope Blindread didint work.... it gets half way there and stops ... and i read the log and it got some errors :- \
  14. Serene Savage Shadowmistress's Avatar
    Mar 2004
    Controlled Chaos
    Sounds like your disk is messed up. Try isobuster and then just copy as a regular data disk.
    Putting the latest upgrade and no cd on the same disk is rather useless in my opinion since the next upgrade they come out with will render that disk unplayable. It's easier to download the newest upgrade once you log onto bnet anyway.
    As for the no cd, there are tons of sites hosting the latest versions of that. Just google it. The no cd file is only a few kilobits in size so no real need to have it on disk.
    I have to use the no cd crack as well. For some reason my drive always heats up too much when I play and just cooks the disk. I've gone through 4 backup disks already in the last few years until I got the crack. I just made a data copy of the original and then download the upgrade and crack each time a new version came out.
    Mar 2003
    Yeah it sounds like you disk has bit the dust I have had some disks take up to 18 hours but it sounds like your disk is just too damaged to copy
    Dec 2005
    Now thats the error i got on Isobuster..
  17. Член BJ_M's Avatar
    Jul 2002
    Canada
    it may be the fact of the HP unit --
    bad rep i believe
  18. Member
    Dec 2005
    so what do i do 2 frickin copy the cd and i dont rlly understand what shadow was saying b4 about updates..
  19. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    He was saying use a certain software to save it to your HDD and use a NO CD crack. The crack will also let you go online without the CD, but if Blizzard updates their site, your crack won't work unless you get an updated crack.
  20. Serene Savage Shadowmistress's Avatar
    Mar 2004
    Controlled Chaos
    First, try to fully copy the information off the damaged cd onto your hardrive. Look into programs that specialize in this. (Try googleing the words "read damaged disk".) Or, try copying with zero's or something and cross your fingers that it's not an important part that's damaged.
    Second, once the data is copied onto your comp and you can see all the different files (not the one file which is an iso disk image, but all the separate files like .exe, .dll, etc.) copy all these files onto a new disk. Burn. That's it.
    Third, install and run starcraft in multiplayer mode. Go log onto Battlenet. The first thing battlenet will do is tell you you need to update your version of sc and start feeding you the download. When it's complete it will restart sc for you.
    Fourth, as sc is restarting a little box pops up telling you what this versions changes/fixes are. Note the version number on this box. They're up to 13e at this point i think.
    Fifth, google "starcraft no cd 13e" for example. Alot of sites will pop up where you can download it. Its only a few kilobits so don't worry about putting it on the disk.
    In another month or two Battlenet will probably force everyone to get the next upgrade. Version 13f or 14 or something. When that happens, EVERYONE who logs onto bnet must upgrade or they can't play online. When that happens, you wait a few days and google for the next no cd crack. The upgrades happen every few months whether we like it or not. We have to get new no cd cracks after every upgrade, whether we like it or not.
    Dec 2005
    thank u~
  22. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    Honestly, if it's only the original Starcraft, you can save yourself loads of time by visiting a local game store and picking up a used copy for $9.99 and then back up the clean copy with the NO CD crack. Then place the disc in a safe spot.
    Me personally, if I had to spend this much time dicking around trying to fix a really scratched disc, it'd be worth the savings of time and effort to just to get a used copy at EB or Game Stop.
  23. Member
    Dec 2005
    i got it my friend just lemme boproow his and i saved iso on dvd-r for later if i had 2 burn it plus my own copy thnx
  24. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    ah, bring back good old tape to tape for the ZX Spectrum to backup your games
    anyone could do that
  25. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    T2T back ups. And I though disc load times would be a pain in the a**.
