nero digital asp vs. xvid
what is best?
i got a new dvd player and it can handle both nero digital standard and xvid.
got many movies in all formats and i'm going to convert those into the best format. should i convert my movies to xvid or nero digital?.
and give me the pros. and cons.
wich one gives the best speeds,quality and compression.
You'll find xvid will give you less headaches should you wish to re-convert the video to another format later .
As for the diff between them , xvid done correctly out perform's nero's digital format as you can tweak it before encoding ... nero dosent allow for much tweaking .. you is pretty well stuck on what nero will do and create . -
Just for the hell of it, I tried Nero Digital when it was first released, and was very impressed by the quality vs file size ratio. Haven't tried since tho, as I don't have a ND capable player (and prefer open standards).
/Mats -
i personally actually perfer divx given the options...i know that xvid does actually outperform it qualitywise (at least when tweaked properly) however, divx just KILLS everything out there in terms of compatability with devices....xvid is close, but its got some problems with playback on certain devices occasionally.....but yea, i agree, between nero digital and xvid, i'd go with xvid
XviD should be every bit as compatible as DivX if you encode both with HT profiles.
Also, are we just comparing video codecs here? Or containers, like say avi for XviD vs. mp4 for ND? Because there is no reason why you can't have XviD in an mp4 container or ND in an avi container. -
compare only the codecs.
wich one gives the best quality and file size and why?
Using FFmpeg with C#,ASP.Net
By DanielTaylor in forum ProgrammingReplies: 0Last Post: 23rd Jun 2010, 05:19 -
Extracting xvid (V_MPEG4/ISO/ASP) from MKV
By 20000RPM in forum Video ConversionReplies: 2Last Post: 7th Feb 2010, 21:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 07:00 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
