  1. Member buzzsaw's Avatar
    Nov 2003
    I created a DVD from a mpeg file using TMPGEnc, and it works fine. The problem is I forgot to add chapters and I no longer have the original mpeg file.
    How can I get the DVD back to a mpeg (if this is what I need to do) to add chapters.
    Thanks in advance.
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    Just import the DVD into TDA and start again.
    He's a liar and a murderer, and I say that with all due respect.
    Feb 2004
    Australia
    Strip the video and audio using vobedit , to demux the complete title set .
    Depending on the audio , it may need re-encoding .
    Use ifoedit to author dvd .
    Ifoedit require's a text file called celltimes , which state's the frame's the chapter's happen .
    According to some ...
  4. vob2mpg may be able to help you in this case........just demux the vob files, re-import them into TDA, chapter and author as needed and burn to disc....
    i'll second TDA..it's all you need. no demux/remux or any of that extra jazz required.
