    Jan 2006
    Hi
    When I play my AVI movie in windows media the sound is in sync.I converted the avi xvid file to VCD using Allok converter.Split it with tmpgenc.Burned it using Nero7 on to VCD.When I play it the sound is in sync at first but as it plays on it gets further and further out of sync.Sound comes to early.How Do I fix it?
    I did this with another AVI XVID and all played well so Im sure it is the original file.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Probably VBR audio in the problem AVI. Convert to CBR and do it over. Common problem.
    /Mats
    Jan 2004
    Spain
    Give VSO DIVXto DVD a go it cured my out of sync probs.
    http://www.vso-software.fr/
    Jan 2006
    how do I convert to CBR?What is CBR Im a little new at some of this stuff.
    XVIDtoDVD wont do I need it XVID to VCD.
    Thanks for the help
  5. Mod Neophyte redwudz's Avatar
    USA
    First you want to check your video with a program like Gspot. Look for MP3 VBR audio to the lower right. VBR= Variable Bit Rate as opposed to CBR=Constant Bit Rate. VBR audio is usually not read properly by an encoder and ends up converted to the wrong length.
    You can drop it into a program like VirtualDub Mod and it will tell you right away if you have VBR. Then you save it out as a WAV and use that in your encoder for the audio source, along with the original video.
    Extracting the audio with VDM: https://www.videohelp.com/guides.php?guideid=837#837
    AC3 audio can also cause problems if not handled properly.
    Jan 2006
    It worked great.Thank you very much for the help.
